Substitute for a failed nylon adjuster nut
Here is the working one(covered in etching primer):
As the screw turns the light casing moves. Lithium grease helps lube the plastic. I never chased the threads yet.
Here is the broken one
Details of the broken fastener
Solution: Ace Hardware SAE nutsert and am M6 1.0mm tap.
Taps easy... the one in foreground is tapped and is now metric
Fits nicely
Done!
