Use the clutch disc and pressure plate that you have now, use the bearing,collar and release lever from the 4 speed in the 5 speed and everything will work just fine. The dimensions of the 4 speed and 5 speed are the same.
Thanks for the good info.
This is correct and very important - the disc, bearing, collar and release lever are specific to the clutch being used. So do not re-use the ones that came with your 5 speed (despite them being in potentially better condition or whatever).
Also, if you have an early model Z, you'll want to retain your early shorter driveshaft. Otherwise, a later model car will utilize the same longer shaft. On an early model, you'll notice that the shifter is close to the edge of the cut out on the tranny tunnel. For this to work, you'll have to use one of those bent shift levers...straight ones wont work.
Great info. What about flywheels? I have a stock '75 280Z with four speed manual and I want to install a five speed manual with a turbo flywheel as part of a turbo swap. How does this change things?
It changes everything.......you'll need a different clutch and pressure plate (for the 240mm flywheel)and a clutch collar to work with the turbo (2 plus 2) clutch. Don't use the turbo clutch IMO unless you've got over 250 h.p........
The juice ain't worth the squeeze!
