Recently Browsing 0
Been having problems with my 72 240Z loosing coolant. I tought i found the reason when i changed leaking pipe next to valve in passenger side. It didnt help. Just few minutes ago, i took the driver side carpet away for hoovering and noticed that the insulation foam was soaked wet!! It was worked as a sponge and sucked all the leaked coolant , there was at least a litre sucked in. It was steadily leaking trough summer and i didnt notice a thing, except that every now and then i needed to add a coolant. DAMN.
I wonder how much damage this leaky core has made, i mean if it has leaked to transmission tunnel..
For core replace, do i need to remove dash..? I can seriously say that im not good enough to do that job
All help appreciated
https://www.classiczcars.com/forums/topic/41110-heater-core-busted/Share on other sites
