Email logins are now active ×
Best to use a N42 or F54 Block?
newtonhubcap
Ok, I attempted to search here which is a better block to use and have come up with little information but some. My question is which block is the better block to use to build up, the N42 or F54 Block?
As I have read they both see to be acceptable. Some say the N42 is better since there is more material left between cylinders when bored out. Other say the F54 since it take advantage of the extra strength of the siamese cylinders. I just want to simply utilize the best block to build up to a 3.1 because we all know that if your foundation is not solid then everything can come crumbling down or in this case go flying in a million directions.
Thanks in advance for you input.
