November 20, 201113 yr Author comment_372273 Zed Head you're a genius! Fins work on hot air cooled engines. Didn't see it that way, thanks. The fuel rail would already be cold not hot, right? I'll be using heat shields too, bought a header with ceramic thermo coat, so it shouldn't get hot. Oh the "Shirley" thing's from Leslie Neilson in the movie Airplane. Corny, I know. Link to comment https://www.classiczcars.com/forums/topic/41136-make-a-fuel-rail/?&page=2#findComment-372273 Share on other sites More sharing options...
November 20, 201113 yr comment_372280 THere are alternatives to "standard"fuel rails.Last picture towards the bottom of the page:http://www.sdsefi.com/index.html Link to comment https://www.classiczcars.com/forums/topic/41136-make-a-fuel-rail/?&page=2#findComment-372280 Share on other sites More sharing options...
November 20, 201113 yr Author comment_372295 Could or is fuel injection used in aviation? Would that allow more altitude without the freezing problems? If I'm looking at the right picture it looks cool as hell but a little over my mechanical and financial abilities. Thanks for the information though. I've read too much on building fuel rails and am over thinking the project. Alot of dicussion about vapor lock from hot fuel so the milled fins came into my plan. Now I realize they're for looks on a car like mine. I'm going to get the smooth "D" rail from Ross Racing and without polishing it, spray with high heat clear coat. It'll stand out a little over my satin black (bar b-q paint) intake. Edited November 20, 201113 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/41136-make-a-fuel-rail/?&page=2#findComment-372295 Share on other sites More sharing options...
November 20, 201113 yr Author comment_372311 I supose it's the lack of air and not the temperature for a fuel injected space shuttle. Oops. Link to comment https://www.classiczcars.com/forums/topic/41136-make-a-fuel-rail/?&page=2#findComment-372311 Share on other sites More sharing options...
November 20, 201113 yr comment_372327 Fuel injection has been used for years on aviation piston engines. Works like a dream. Link to comment https://www.classiczcars.com/forums/topic/41136-make-a-fuel-rail/?&page=2#findComment-372327 Share on other sites More sharing options...
November 21, 201113 yr comment_372351 Could or is fuel injection used in aviation? Would that allow more altitude without the freezing problems? If I'm looking at the right picture it looks cool as hell but a little over my mechanical and financial abilities. Thanks for the information though. I've read too much on building fuel rails and am over thinking the project. Alot of dicussion about vapor lock from hot fuel so the milled fins came into my plan. Now I realize they're for looks on a car like mine. I'm going to get the smooth "D" rail from Ross Racing and without polishing it, spray with high heat clear coat. It'll stand out a little over my satin black (bar b-q paint) intake.If all things are correct,a FI car can not "vapor-lock". Link to comment https://www.classiczcars.com/forums/topic/41136-make-a-fuel-rail/?&page=2#findComment-372351 Share on other sites More sharing options...
February 23, 201213 yr comment_381763 I have a blank fuel rail stock but need to find the layout dimensions for drilling. Anyone have them by chance? Link to comment https://www.classiczcars.com/forums/topic/41136-make-a-fuel-rail/?&page=2#findComment-381763 Share on other sites More sharing options...
February 23, 201213 yr Author comment_381783 I haven't gotten that far yet, sorry. Rebuilding the motor and replacing dry rotted bushings presently. I was thinking I could lay 2ft piece of similar size wood and transfer the measurments. Link to comment https://www.classiczcars.com/forums/topic/41136-make-a-fuel-rail/?&page=2#findComment-381783 Share on other sites More sharing options...
February 23, 201213 yr comment_381823 I have a blank fuel rail stock but need to find the layout dimensions for drilling. Anyone have them by chance?I have an after-market round aluminum fuel rail and these are the dimensions:1-9/16" from the front end to the #1 fitting,*spacing is center-line* 2-3/8" between #1 and #2, 3-3/4" between #2 and #3, 5-3/8" between #3 and #4,3-3/4" between #4 and #5,2-3/8" between #5 and #6,1-9/16 to the end at the firewall.The cold start valve fitting is between #2 and #3, opposite the injector fittings at approx. 60 deg, and there is a fitting for a Summit Racing lquid-filled fuel pressure gauge near the front throttle rod bearing tower (near the dash pot) mounted slightly upward, easily read while standing at the driver-side fender. Edited February 23, 201213 yr by Willoughby Z add't'l info Link to comment https://www.classiczcars.com/forums/topic/41136-make-a-fuel-rail/?&page=2#findComment-381823 Share on other sites More sharing options...
February 23, 201213 yr Author comment_381828 Thank you! That's going to be a great help. Link to comment https://www.classiczcars.com/forums/topic/41136-make-a-fuel-rail/?&page=2#findComment-381828 Share on other sites More sharing options...
February 23, 201213 yr comment_381831 Thank you! That's going to be a great help.You're welcome. Just remember, measure twice/ thrice, drill and tap once! Link to comment https://www.classiczcars.com/forums/topic/41136-make-a-fuel-rail/?&page=2#findComment-381831 Share on other sites More sharing options...
June 27, 201212 yr comment_394185 Kris,Thanks for the info on that fuel rail. About to tap and drill. Would you have any pictures to look at?John Link to comment https://www.classiczcars.com/forums/topic/41136-make-a-fuel-rail/?&page=2#findComment-394185 Share on other sites More sharing options...
