Stock exhaust is oK if you don't plan on any future upgrades to the engine.
If you plan on a header or any other upgrades to the engine, go with their 2 1/2 inch "turbo" exhaust. If you buy a header, it's probably best to go all out and get one with the ceramic coating, as it will prevent rust and even help cut down in the heat under the hood.
Yes, they have a "targa" exhaust in the catalog, that would be fairly good with the stock manifold. Plus, it does have the resonator so it shouldn't be too loud. $139.95
For $149.95 you could get the "turbo" 2 1/2 inch exhaust to use with the stock manifold.
Guess it is up to you, or you could find a quality exhaust shop that might be able to make up one for less or about the same amount.
