October 24, 201113 yr comment_370069 These can work pretty well to find out where a wire is going to. Link to comment https://www.classiczcars.com/forums/topic/41152-3-orphan-wires-in-body-harness/?&page=2#findComment-370069 Share on other sites More sharing options...
October 24, 201113 yr Author comment_370074 Cool thanks! I will get one. I always wanted one. I never knew the price dropped so much. I remember looking at one in the late 80's called the Fox and Hound. It was ~ 200 to 300 if I recall correctly... heck I spent $80 on a weidmeuller co-ax cable stripping termination tool now a similar is $10 at radio shack.In subsea telecom we put a 5Hz to 150Hz AC "tone" on the cable for ROV's and sometimes divers to detect under the ocean floor... good to about 750km at 10Hz then the capacitance has eaten the signal. Link to comment https://www.classiczcars.com/forums/topic/41152-3-orphan-wires-in-body-harness/?&page=2#findComment-370074 Share on other sites More sharing options...
October 24, 201113 yr comment_370077 My 9/71 has a solo red/white in that area. It has a connector at that area and the wire runs into the engine bay area and it comes from the dash area. It's probably a 14 guage wire. I can trace it down later if that is what your talking about, and I can take a pic if that helps. Link to comment https://www.classiczcars.com/forums/topic/41152-3-orphan-wires-in-body-harness/?&page=2#findComment-370077 Share on other sites More sharing options...
October 24, 201113 yr Author comment_370082 Thanks Steve,The red wire on mine goes back to the body harness that feed the rear of the car so it seems to be a different wire. Link to comment https://www.classiczcars.com/forums/topic/41152-3-orphan-wires-in-body-harness/?&page=2#findComment-370082 Share on other sites More sharing options...
October 24, 201113 yr comment_370090 Wouldn't possibly be a fuel pump wire? I know mine is green, but my 71 was equipped with the wiring for an electric pump. Link to comment https://www.classiczcars.com/forums/topic/41152-3-orphan-wires-in-body-harness/?&page=2#findComment-370090 Share on other sites More sharing options...
October 24, 201113 yr Author comment_370091 Thanks!The green one is accounted for and is one of two that I have connected. The other is the door& Room which are two wires tied together that go to the door switch. Link to comment https://www.classiczcars.com/forums/topic/41152-3-orphan-wires-in-body-harness/?&page=2#findComment-370091 Share on other sites More sharing options...
October 25, 201113 yr Author comment_370145 Red wire goes into the harness. I wrapped the red tape (not factory or PO) around it to hold the old black tape that I unwound to check and see that the red wire was factory. Link to comment https://www.classiczcars.com/forums/topic/41152-3-orphan-wires-in-body-harness/?&page=2#findComment-370145 Share on other sites More sharing options...
October 25, 201113 yr comment_370161 Could that possibly be that famous #26 single wire connector from the Single Wire Connector Index we discussed on another post?(By the way, I presume you already know, those two wires to the right of the red wire are for your Step Light.)I can't find a single indication of a RED only wire going to the back of the car. Can you unwrap the bundle just aft of the passenger seat and see if it DOES go all the way to the back of the car and not stop at the passenger seat area? The passenger seat had the Seat Belt Warning Buzzer circuitry added for later builds (still considered "early") as well as the tattle tale sensor attached to the bottom of the seat cushion AND the Parking Brake Lead. I'm still looking for a wire schematic that encompasses all those circuits.HTHE Link to comment https://www.classiczcars.com/forums/topic/41152-3-orphan-wires-in-body-harness/?&page=2#findComment-370161 Share on other sites More sharing options...
