  Blue said:
I just matched the original config.... however the seat belt hooks were also on that side?
Yes, the seatbelt hooks should also be on the other side of the seat backs. If there are no holes on the other side of the seats, then they were either recovered and someone put them on other side, or the seats were disassembled and the hinges were put on the wrong sides. To make them correct again, you could remove the bolts that hold the seat backs in place and swap the sides, or you could remove and swap both sets of hinges.
-Mike
  • 1 month later...
