One of the more popluar Upgrades for 240Z's is to get the 4 piston brake calipers from mid 1980's Toyota 4X4 trucks and install them. It's a straight bolt on deal. You just have to trim the backing plate a bit for clearance to the caliper. You can also get a ZX Master Brake cylinder to move more fluid with the larger calipers.
One of our members, Ross Corrigan ;has a business called Modern Motorsports ( at http://www.modern-motorsports.com/ ) and sells an upgrade kit for Z's that sounds interesting. He can hook you up with the stuff to do Disc Brakes on the Rear as well. Check him out.
