Hey guys, o.e style wire hose clamps, where do i go.....?
rahail240
This will probably sound horrible, but...
It might be possible to make some. It looks like a simple enough design. One threaded hole, two unthreaded holes, a screw with a ground-down tip, a washer, and a bent-up wire. Yellow zinc plating to complete it.
I've seen this style of clamp still used for intake boots, e.g. on my '92 Saturn (which I suppose is not really a modern car anymore, although I bought it new). It wouldn't surprise me if someone still makes them.
If you need some right now, you can pick some up on e-bay, but you need to be careful there. ‘reddat’ sells nice ones, but they are pricey and his shipping is high. There are other sellers on e-bay that sell these with a hex head screw, but I do not believe the cars came with this style (personally, I think they are a poor imitation) . If you are patient, Espirit is supposed to be working on reproducing these and should have them available soon. His work is top quality. Not sure if that helps much.
Reddat's clamps appear to be the hex type also at least on the larger ones like heater or radiator hose clamps. Edited by sblake01
There are several sizes of clamps:
fuel hose from fuel line to fuel pump
fuel line from fuel pump to carb
heater hose
radiator hose
vacuum line (brake booster)
Tell me what sizes and quantity you need. I recently yellow zinc plated about 50 clamps (most with the round head). Perhaps I can assist you.
Keith
  • Who's Online   1 Member, 0 Anonymous, 726 Guests (See full list)
