Clubbers,
While I had my Z up on stands, I gave a push-pull to the half-shafts. The left (driver's) side seemed to have some play. I removed the half-shafts, expecting a worn U-joint but instead discovered that the source of the play was the differential itself. I don't have a micrometer and its unmeasurable with a ruler, but their definitely is some in-out movement, along with an accompanying clunk (faint) when I tug and push on the bracket that attaches to the half-shaft.
It's a 1972 with the 4-spd stock differential, a R-200.
Is this something to be concerned about? Or normal play in an unloaded condition? The right (passenger side) does not have any play.
Chris
https://www.classiczcars.com/forums/topic/41211-differential-play/
Normal. The side gears and pinion gears inside all have a bit of lash, you're just feeling it through the halfshaft. If the halfshaft moved up and down a lot or the car made some hellacious noise when you turned, then you should be worried, but what you're describing is normal. Also normal to be able to twist the driveshaft a little bit before the halfshafts start to move.
Thanks Jon,
Your description of a normal differential matches what mine does. It's always a relief to not have to spend time and money.)
Zedyone_ I believe automatics used the R180, manuals the R200 in 1972. For the next few years as well, maybe even until the ZX.
Chris
Lots of people install R-200's whether they need it or not. If you drop a V-8 or engine with tons of power in your Z, you probably need one. If not, you're wasting money.
I don't know about you, but I don't think putting in a 3.9 R200 was a waste of money in my (non-V8) Z. Many others install the R200 in order to change overall gear ratio, along with the added strength. Aalthough you can find R180 diffs with similar ratios, they are tougher to come by. I don't see any problem with having an R200 in an L-powered Z, it just didn't come from the factory that way.
I went off what my Chilton's manual said by visually matching the type of connection to the half-shaft. Hayes refers to 240Z type and 260Z type transmissions at one point and R180 = 260Z and R200 = 240Z at another point and that manuals received R200s and automatics R180s.
The FSM is silent on the R180 vs. R200 question. The illustrations in the 1972 FSM match up with what is installed on my 1972 so I assumed that it is the factory differential. Because it has a flange-type connection which two independent repair manuals identify as R200s, I made the big guess that 1972s had R200s.
Could be wrong, of course.
More generally, what's the difference between the two other than how it connects to the half-shaft?
Chris
Chris
Both the R180 and R200 diffs have flange connections to half-shafts (driveshafts in Nissan-speak). Thus, 240Z half-shafts can be used with the R200. They are not the difference.
The biggest difference between the R180 and R200 are the physical size (180mm ring gear vs. 200mm ring gear).
Edited by LeonV
  • 3 weeks later...
That makes sense.
I've been busy with big (mis)adventures on the underside of my Z. Finally got it though. I think.
Chris
