Antenna Won't go up
Ben's Z
My power antenna worked fine when I bought the car but when I set it up for the suspension refreshing I put the antenna down, now it will not go back up. The motor works, in either direction. I was going to just jump into it, but wanted to check with the experts first in case it is always the sample problem...
You'll be well served to pull the antenna assembly and disassemble for cleaning. Lots of water and crap gets in it over the years. Lube the areas that need it w/water resistant grease. You may also find the white "snake" that actually drives the mast has become unattached from the reel or has broken. It is not a difficult thing to do and be sure to unplug the water drain hose.
