Stumble and Back fire
Ben's Z
The 77 smells like it is running rich and the spark plugs tell me the same. I get a backfire and stumble pulling away from a stop under partial load at low revs. That being said I seem to be getting the same problems others have had I found searching similar posts about EFI problems; and all those seem to indicate air bypassing the AFM or the coolant temp sensor; and others indicate a lean condition with that. My boot seems to be in good shape. What kind of tests can I run on that sensor to check that? Any other suggestions? I want my pile running as good as this pile will run for my trip to Fredericksburg next month. :cool:
After this trip I am going to pull my Turbo motor from the parts car, have the head refreshed and put that in the 77 anyhow.
  • Who's Online   1 Member, 0 Anonymous, 638 Guests (See full list)
