Posted November 9, 201113 yr comment_371286 Recently i have noticed an issue with my idle. when i turn the headlights on it gets very rough. The in dash voltmeter reads a little over 12 without them on, and goes to 12 when on. Two days ago i noticed the voltage was getting lower and lower as i was driving down the road until the car died. I replaced the battery and the alternator and the voltage still seems low. Is there a component i am missing?The only thing that has changed since i noticed the issue was i removed the cars after market cd player which no longer worked. Link to comment https://www.classiczcars.com/forums/topic/41280-turning-on-headlights-makes-idle-rough/ Share on other sites More sharing options...
November 9, 201113 yr comment_371309 Your charging circuit isn't charging. Blindly replacing parts in an attempt to solve the problem is not recommended. There is a complete testing and troubleshooting procedure in the FSM. You have not even stated what car this is happening to... Link to comment https://www.classiczcars.com/forums/topic/41280-turning-on-headlights-makes-idle-rough/#findComment-371309 Share on other sites More sharing options...
