76 280 Shutsdown randomly at any speed.
johnccc
76 280 power will just shutdown randomly. Anything time, any speed. I have to turn it over 5 or 10 times before it fires up. Once it does it runs great until the next time. Could be 10 mi or 100.
Temperature not an issue. No exhaust or fuel issues.
I agree with ignition module. Heat kills them over time.
You can verify by watching the tach the next time it fails. If the needle falls faster than the engine revs die when coasting then it is an ignition problem.
For a fix, I recommend this rather than buying a new module: http://atlanticz.ca/zclub/techtips/distributor/index.html
  • 1 month later...
Do you have a caps on the battery neg/Pos terminals I had the same problem ended up checking every major electrical component in ignition circuit and it was the battery shorting out the car when the hood would make contact with the battery
  • Who's Online   1 Member, 0 Anonymous, 367 Guests (See full list)
