Thanks for the warm welcome.
It's pouring here so I can't take anymore pics at the moment but here's a couple more.
L28 F54 block with a ported E88 head, stage II cam, roller shaft Z-therapy SU's and a 5 speed, it's pretty peppy.
Cheers,
Doug
Welcome. With the name 'c6fan' are you into Vettes by any chance? I have an 84 C4 that I kind of 'lucked into' the explaination of which would be a long, off topic story. Anyway, nice Z. I think I've seen that car before. I used to go to quite a few shows in that area.
Just a suggestion - you may want to research putting the original air breather/filter back on your car - it has built in air horns that will give you more power than you are getting currently with the filter set up your are running. IMO...................
