Do you the name of this irishman? cant find him on hybridz
Hi Robin,
Seen yours before & VERY impressed. The Irish car I think you're looking for belongs to jay28 who can be found through www.zclub.net
Edited by Arne
quote repair
Quoting and subbing to this thread just so I can use it for reference.
I like what you've done to the car so far. I hope to see more photos.
Well some kind of speclist :
Engine -2,6 litre 6 inlinw Ohc
-Double Su carburaters
-Twin air airfilters
-Inlet sandblasted and painted
-Janspeed 2x 3-2-1 uitlaexhaust manifold
-Megan racing Muffler ( will become a smaller one )
-Magnecor 8mm sparkplug wires
Exterior:
-Zg fiberglass fender flares
-Xenon polyurethane Airdam
- BRE style spoiler
-Fiberglass bonnet with original airvents
-Fiberglass fenders at the front
-Fiberglass headlightbuckets
-All the chrome trims will become flat black
-Bumpers will become flat black
-H4 conversion with clear headlights and 6000k bi-xenon HID
-Taillights changed too double taillights using the foglight
-Aluminium race Fuelcap conversion
Interieur:
-fully stript
-removed all the isolation off the floors
-Qsp deepdish 90mm drift steering wheel
-Omp racingseats
-4 point harnesses
-Dashboard will be flocked
-Probably i will make a 10 point rollcage in it.
Handling:
-Mazda lantis ba d2 racing coilovers customised
-Complete Polyurethane bushing
-The complete suspension is sandblasted and coated black
-R200 3:9
Wheels:
-Rota rb-r/x (Front 9 J et-13 --- Back 9,5J et-19 )
Tires:
Falken 452 215/40/17 stretched
Brakes:
-Vented /Drilled /slotted 300zx z31 non turbo rotors front
-Drilled/ slotted 300zx z31 non turbo rotors back
-Toyota landcruiser vented 4 pot calipers front S12W
-Nissan 200sx s14 rear calipers back
-Modern motorsports 240sx brackets customised to fit the larger s14 calipers
I think is the first 2+2 that I like. I wonder if it would look good if you were able to hide the b pillar somehow. Amazing work. Keep up the progress
well i was thinking about that the same way but i think it is hard to change the design.
But i have seen one Z ( Aardvarks Z , i think a well known name in the Z scene ) that doesnt have them anymore.
  • 1 month later...
Updates:
All the fiberglass panels on the front are fitting correct. Finishing touch has to be made with filler
I can mount my h4 headlights again. The fiberglass panels had no mounting point so i had to cut them out of the steel ones which had a lot of rust.
Now it looks like it is original
Bought some Volkswagen beetle fenderrubber to mount between the fender and the flares. This fills the gape between them.
Enginebay is ready to be paint. The underside of the car has been sprayed completely with anti stone chip spray. ( Dont know the exact the english name )
My right side door was completely rusted so bought a new perfect one together with a perfect drivers side one.
Some older pics of applying and sanding filler to the body.
Some newer. These are the most common jobs i am dealing with. Hop the bring the car to the painter at the end of may
Dashboard, Dashboardcabin and ventpanel in front of the window are back from the flock company. It looks perfect.
thats it for now. I hope the next pics are on the painters truck.
Edited by Robin260z
