November 27, 201212 yr comment_407801 what else needs finishing? Link to comment https://www.classiczcars.com/forums/topic/41424-my-240kc110-build-thread/?&page=11#findComment-407801 Share on other sites More sharing options...
November 28, 201212 yr Author comment_407860 Not much, i need to do all the electronics now fit dash, new starter motor, fix up brake lines( i have them all here), clutch line. I need a few new parts to fit trim. Get exhuast made up. Then hoply in the New Year i will get the auto trimmer to do a boot install and make up some kick panels that will fit speackers(so they can be taken out if i want a stock look down the line.) So for a normal person probably 3-6months if motor works fine, for me 12-18 months Link to comment https://www.classiczcars.com/forums/topic/41424-my-240kc110-build-thread/?&page=11#findComment-407860 Share on other sites More sharing options...
April 8, 201312 yr Author comment_419849 Hmmm 4 months into new year and not much has happen i have almost all the parts to SS trim now so think i will do that soon. I have played around with the dash just waiting on some more parts to arrive then will hope to get that in too. Link to comment https://www.classiczcars.com/forums/topic/41424-my-240kc110-build-thread/?&page=11#findComment-419849 Share on other sites More sharing options...
April 8, 201312 yr comment_419870 or new clips and rubbers Link to comment https://www.classiczcars.com/forums/topic/41424-my-240kc110-build-thread/?&page=11#findComment-419870 Share on other sites More sharing options...
April 27, 201312 yr Author comment_421692 Anyone know if these "sedan" springs also fit he coupe?http://www.ebay.com.au/itm/NISSAN-DATSUN-240K-1972-77-SEDAN-FRONT-REAR-LOW-30mm-LOWERED-COIL-KINGSPRINGS-/150722130731?pt=AU_Car_Parts_Accessories&hash=item2317bd332b Link to comment https://www.classiczcars.com/forums/topic/41424-my-240kc110-build-thread/?&page=11#findComment-421692 Share on other sites More sharing options...
April 27, 201312 yr comment_421702 yep all the same Link to comment https://www.classiczcars.com/forums/topic/41424-my-240kc110-build-thread/?&page=11#findComment-421702 Share on other sites More sharing options...
August 9, 201311 yr Author comment_429336 Slow and steady.............................................. Never gets finshed Fitted some of me freshly repaired and polished trim and the side Edited August 9, 201311 yr by blk180 Link to comment https://www.classiczcars.com/forums/topic/41424-my-240kc110-build-thread/?&page=11#findComment-429336 Share on other sites More sharing options...
August 9, 201311 yr Author comment_429337 Mook up the wing(60mm lower springs on a boat from Japan) And DAT arse!!! Next to get the motor running....... one day Link to comment https://www.classiczcars.com/forums/topic/41424-my-240kc110-build-thread/?&page=11#findComment-429337 Share on other sites More sharing options...
August 14, 201311 yr comment_429697 Looks great- have you had any luck sourcing door rubber seals at all? Link to comment https://www.classiczcars.com/forums/topic/41424-my-240kc110-build-thread/?&page=11#findComment-429697 Share on other sites More sharing options...
August 14, 201311 yr Author comment_429707 Which ones, i brought htem all off Yahoo new. Link to comment https://www.classiczcars.com/forums/topic/41424-my-240kc110-build-thread/?&page=11#findComment-429707 Share on other sites More sharing options...
August 14, 201311 yr comment_429719 Looks ace....nice progress. Link to comment https://www.classiczcars.com/forums/topic/41424-my-240kc110-build-thread/?&page=11#findComment-429719 Share on other sites More sharing options...
August 14, 201311 yr comment_429740 The one rubber seal that is between the back passenger window and the front window. I'm also looking for tie rod ends. Link to comment https://www.classiczcars.com/forums/topic/41424-my-240kc110-build-thread/?&page=11#findComment-429740 Share on other sites More sharing options...
