Email logins are now active ×
popping through the exhaust at 4500 rpm or so.. HELP!
Zedyone_kenobi
Drove the car more today. BIG improvement can be confirmed. Car feels great at any throttle position.
At about 5000 rpm at part throttle it still had a popping but I could only get that to happen in second gear not first. If I was not so anal I could live with this just as it is because under normal driving it is butter smooth. It still leans out as rpm goes up with part throttle but not nearly as fast. There was no doubt a vacuum leak in that gasket
Normal driving AFRs are about 13 :1 at steady throttle. I could probably run it richer and not worry about it but that is most likely masking the real problem
I will drive it more and report back
I'm betting it's electrical now.......plugs, points, condenser......maybe a bad plug wire.....I once had a similar problem with almost new plug wires. When I put a new distributor cap on there was a green electrical corrosion where the wire snapped into the cap.
Edited by Diseazd
We took some shots at the electrical system. I bought new plugs and wires and installed and measured the resistance through all of them. I swapped out dizzy with a good pertronix and a coil with a known good car. I even replaced the balast resister even though it is bypassed. I ran a jumper from the battery to the coil to take the tach out of the picture. I swapped out a cap and rotor as well
Edited by Zedyone_kenobi
At WOT THe AFR stays around 12.9 to13.5
Steve, Doradox, You guys are probably right. Those were the words of a desperate man talking...
I have rulled out the 12V power side of the coil getting enough power with the jumper trick. However, I have not checked to see the quality of the coil ground. Although I think that would be just as evident at WOT as it is part throttle.
