Email logins are now active ×
new to z need some help with experience z owners! please
mn91
i added some brake fluid and pumped the clutch but the fluid is not getting pumped into the line.. so is my master out? or do i just need to bleed out the system. and also where is this FSM that i could download?
Ok well I just ordered a new slave cylinder.. But got some bad news guys. I pulled my plugs to do a compression test and they were all foul. This explains the fuel smell in my oil. I Also did an oil change and drive the at for about 50 miles and oil starting to smell like gas again. I did a compression test and got 125 give or take a 5 on all cylinder. That's fairly low... My exhaust was blowing out white smoke after a fresh oil change but after 5 mins of doing it it stopped and doesn't do it at all anymore. Now it only blows out black smoke if I really give it gas. Plus when I'm at wot it stumbles. Probably due to plugs being foul.. So what you guys think. Bad rings??
Head gasket would make me feel better.. But would that cause gas to get into oil? I think I'm running rich bc there is a strong fuel smell sometimes. And wouldn't a crack headgasket leak coolant into the oil? Thanks for the respond
Depends on where the damage is on the gasket. There are passages from block to head. Oil, coolant and cylinders are all separated by the gasket material in the space between the block and head. Gasket damage between oil passage and coolant passage= coolant in oil/ oil in coolant. Gasket damage between cylinder and an oil passage, you get the picture. Valve train problems will allow oil into top of cylinder/ unburnt fuel back up into the head.
Check valve adjustment, then do a wet compression test. Give a little shot of oil in the plug hole and check the lbs. If the pressure goes up wet, then the rings are losing the pressure. If the pressure is the same wet or dry, then it's a good chance that it needs a valve adjustment/job.
  • Who's Online   1 Member, 0 Anonymous, 557 Guests (See full list)
