Posted November 21, 201113 yr comment_372419 I just got done installing a 3 row rad.i tried installing a new temp sensor but the probe was stuck, it would not come out. my question is, will a 240z thermostat housing fit on an L28????the part that bolts onto the motor. it seems like the previous owner used JB weld on the sensor and other bolts too. I'm assuming mine is a 240z housing because the top water outlet only has two holes to bolt it in place??? Link to comment https://www.classiczcars.com/forums/topic/41432-cooling-system/ Share on other sites More sharing options...
