November 26, 201113 yr Author comment_372852 Thanks for the input everyone !Best offer so far is $6KUPDATE 11/25/11: I JUST STARTED THE CAR , IT STARED RIGHT UP BUT WILL NOT IDLE PROPERLY. THE CARBURETOR'S PROBABLY NEED TO BE REBUILT. FUEL IS COMING OUT OF BOTH OF THE CARB'S BREATHER TUBES THAT GO TO THE STOCK AIR CLEANER. I AM NOW TAKING THEM APART AND CLEANING THEM OUT. I ALSO INSTALLED NEW SPARK PLUGS, POINTS, CHANGED OIL & FILTER, FLUSHED RADIATOR, LUBRICATED PISTON CYLINDERS WHEN I CHANGED SPARK PLUGS, AND HAND TURNED THE CRANK BEFORE STARTING TO PROTECT THE RINGS. I ALSO RAN THE FUEL LINE INTO GAS CAN WITH FRESH HIGH OCTANE GAS BYPASSING THE CAR'S GAS TANK WHICH NEEDS TO BE CLEANED (GAS TANK IS EMPTY). Link to comment https://www.classiczcars.com/forums/topic/41435-what-do-you-think-my-z-is-worth/?&page=3#findComment-372852 Share on other sites More sharing options...
November 29, 201113 yr comment_373214 I'd take that 6k offer and run. I bought my 1 owner 70 with 69k for 1800 in similar shape, after sitting for 10 years. Link to comment https://www.classiczcars.com/forums/topic/41435-what-do-you-think-my-z-is-worth/?&page=3#findComment-373214 Share on other sites More sharing options...
November 29, 201113 yr comment_373238 You should take that offer .Good luck to you ! Link to comment https://www.classiczcars.com/forums/topic/41435-what-do-you-think-my-z-is-worth/?&page=3#findComment-373238 Share on other sites More sharing options...
