Posted November 22, 201113 yr comment_372534 Fellow Z'ers.Does the clutch release bearing setting need to be adjusted with clutch wear or does it only need to be checked and adjusted when a new clutch is installed?Chris Link to comment https://www.classiczcars.com/forums/topic/41444-clutch-release-bearing/ Share on other sites More sharing options...
November 22, 201113 yr comment_372543 The adjustments are to the clutch linkage. After it's adjusted correctly, the hydraulics are self-adjusting at the master cylinder and will take up disc wear, which is a tiny distance anyway. Link to comment https://www.classiczcars.com/forums/topic/41444-clutch-release-bearing/#findComment-372543 Share on other sites More sharing options...
November 24, 201113 yr Author comment_372711 Thanks, Zed Head.Fear of snapping the reservoir off had my relying on a reading of the hydraulic fluid level through the translucent plastic. It was only when the clutch action rather suddenly changed that I took off the top and discovered: 1) essentially no fluid left and 2) what I thought was the fluid level was formerly fluid turned black gunk. Cleaned out the reservoir and bled the lines till the fluid ran clear. Clutch pedal height and play spec'ed out so I'm thinking I should be OK. And adding yet another level to the weekly under hood check.Chris Link to comment https://www.classiczcars.com/forums/topic/41444-clutch-release-bearing/#findComment-372711 Share on other sites More sharing options...
