Email logins are now active ×
Clutch Release Bearing
Jetaway
Thanks, Zed Head.
Fear of snapping the reservoir off had my relying on a reading of the hydraulic fluid level through the translucent plastic. It was only when the clutch action rather suddenly changed that I took off the top and discovered: 1) essentially no fluid left and 2) what I thought was the fluid level was formerly fluid turned black gunk. Cleaned out the reservoir and bled the lines till the fluid ran clear. Clutch pedal height and play spec'ed out so I'm thinking I should be OK. And adding yet another level to the weekly under hood check.
Chris
