  • 5 weeks later...
Started sanding the guards down..
And Found this...
Bodge jobs. Bog straight over big rust holes. Found them in both front guards, the doors, sill panels and rear quarters. So pretty much everywhere.
From what i thought was going to be a quick job, sure as hell isnt now... :( *sigh*
Tmrw im cleaning front wheel wells, spraying them black and possibly getting the engine bay in undercoat..
ok. after having a dummy spit, i went out this morning and got stuck in. Cleaned up the inner guard and sprayed it in killrust enamel. theres a rust hole in bottom right, which i will cut out and weld up tonight hopefully.
Seeing this definatly bumps moral up after staring at rust all the time
Before..
After...
