Posted November 26, 201113 yr comment_372857 i was on a drive about a hour and a half out of where i live and when i started to drive agine i get this klunk in the rear pass side. i just did a rear brake job and did what the book said to the T and now after a long drive i have a vibration and a sort of klunk in the rear end. o dose any body live in the killeen/fort hood area? Link to comment https://www.classiczcars.com/forums/topic/41472-klunking-in-the-pass-side-rear-after-long-drive-and-to-much-peadle-to-metal/ Share on other sites More sharing options...
November 26, 201113 yr comment_372859 Have you checked your lug nuts? That's the only thing that you would loosen and tighten for a brake job. Link to comment https://www.classiczcars.com/forums/topic/41472-klunking-in-the-pass-side-rear-after-long-drive-and-to-much-peadle-to-metal/#findComment-372859 Share on other sites More sharing options...
November 27, 201113 yr comment_372937 Z mid to rear clunks are often hard to trace and often multi-symptomatic (requiring a few U-Joints, Bushings, bearings, Mounts, bolt tightening). Does the problem happen on shifting, braking, throttling, hitting road bumps, when playing Parliament Funkadelic.... For local support, check out http://czot.org. Austin Z-Clinic is about an 1.5 hours away. Link to comment https://www.classiczcars.com/forums/topic/41472-klunking-in-the-pass-side-rear-after-long-drive-and-to-much-peadle-to-metal/#findComment-372937 Share on other sites More sharing options...
November 27, 201113 yr comment_372958 Silvey, jack the rear of the car by placing the jack under the diff pumpkin. Now try lifting and lowering the pass. side strut assembly. I suspect the rubber top strut insulator separated/got torn. It happened on my 76 and was making the clunking noise you described.It also can be attributed to the worn diff member top brace. Do a search for a Ron Taylor (RT) differential mount mod. But like GreenZ said, there might be quite a few causes. Link to comment https://www.classiczcars.com/forums/topic/41472-klunking-in-the-pass-side-rear-after-long-drive-and-to-much-peadle-to-metal/#findComment-372958 Share on other sites More sharing options...
