26th-z you have a good point. In the last 24 hours he has learned how to find the ID number on the block, change/gap spark plugs, bleed brakes and replace the throttle return spring. While he was changing the spark plugs he learned the hard way to remove the spark plug wires from the boot and not by yanking on the wire. So then he learned how to repair the spark plug wire/boot. Next he will need to ID the holly carbs and buy two rebuild kits. I'll rebuild one as he learns and he will do the 2nd. After that he will learn how to do the timing and hopefully the engine will run smooth.
Hello, My name is Darryn and (with) my ... wallet ... I am going to the poor house I just know it.
Especialy once you get an insurance quote....
16 yr. old male + Z (Sports Car) = BIG BUCKS / year
And once he gets his first ticket (not IF, WHEN) ....
BOOOM PAYMENT INCREASE!
You may be much better off restoring that car for 4 years and then letting him drive it, it won't be CHEAP then, just CHEAPER.
FWIW
E
My mistake. I thought he told us it was holly but you are correct about it being a Weber. When we go a buy the rebuild kit how do I know what kit I need? Are those carbs stock?
Edited by derbyD
They could also be Holley 5200's (Pinto carbs). They will fit the same manifold as a Weber 32/36 DGV and were fairly plentiful back 'in the day'. Hard to tell with the air cleaners on........
The spot weld breakage on that bracket seemed to happen mostly to the late 73's. Mine also had only 2 not so good welds instead of the 3 that should be there. I have confirmed with quite a few other 73 owner's who also had the same breakage, only 2 welds.
If our paths cross, you get the doughnuts, I'll tell you the stories. :)
Bonzi Lon
