Please help me choose between two tire sizes for my 14X7.0 slots.
PastorMike
Hello all, this is my first post.
I am doing a staged restoration on a sun-baked '71 240 (more on this later), and need an answer to my tire question.
The rims are dealer stock, aluminum slotted, casting shows 14X7.00 on the inside. Offset measures -10mm (yes, minus 10, the original dealer sold Oldsmobiles) which provides a deep dish, and some tire to fender issues (during turns) if the tires are too large. It has 185/70 14 on it now... yuck. Look terrible, and not a legal mount per width requirements.
I have settled on two possibilties and need some influence from the community. Both of these fit the 7" rim: 195/60 14 Michelin Pilot Exalto A/S, or 195/65 14 Michelin Harmony. I want to keep the rims at least for now, not a lot of choices out there. I will probably lower the car an inch or two with new springs.
I have spent hours on the wheels and tires forum, seen things I'd like to do, but no new wheels until the restoration is complete.
Thanks.
Cozye, according to tirerack's data, 195/70/14 only accommodates a 6.5" rim max (not that you can't go to 7"). The 195/65/14 goes to 7".
Also, remember that I have a large negative wheel offset on the original slots that swings a larger tire into the valence during turns (wish I had zero offset, would have chosen 195/70/14's). The right-side valence was already rolled due to a larger tire interference issue.
Your wheel/tire setup is very nice looking.
Depends on the brand and who you ask. I researched it. Tire shop also checked their data sheet. They said no problem. Some manufacturers also list 5.5-7, some 5.5-6.5 . Its not a problem
Also keep in mind the 65 is shorter, higher revs, speedo off more, and hard to get.
Edited by cozye
  • Who's Online   1 Member, 0 Anonymous, 439 Guests (See full list)
