April 21, 201212 yr Author comment_387867 UPDATEI have the r180 diff mocked up in the 79. I left the shafts on it and they seem to be the right length. My only problem is the bolt that the rear of the diff mounts to is in the wrong place. I can see where it could slide forward....but how? Link to comment https://www.classiczcars.com/forums/topic/41502-differential-question/?&page=3#findComment-387867 Share on other sites More sharing options...
April 21, 201212 yr Author comment_387868 Here's a photo of the bolt on the parts car. You can see how the bolt can be in two different spots. Question is, how do I adjust it? Link to comment https://www.classiczcars.com/forums/topic/41502-differential-question/?&page=3#findComment-387868 Share on other sites More sharing options...
April 21, 201212 yr comment_387875 da... Just saw the picture........ never mind... bad reply.. delete Edited April 21, 201212 yr by Carl Beck Link to comment https://www.classiczcars.com/forums/topic/41502-differential-question/?&page=3#findComment-387875 Share on other sites More sharing options...
