Zedyone_kenobi Posted December 5, 2011 Share #13 Posted December 5, 2011 you said it had a 370 rear end, is that a Datsun rear end or did he swap a solid rear axle. Also, the Dart 2.02 heads are almost a grand by themself if they are aluminum. If he has solid lifters than he running a rather aggressive cam and valve adjustments are something you will need to learn to do. Not hard, but it is maintenance that will be required. Roller rockers are just par for the course with a large cam, no biggie there. You need to find out if they are 1.5 or 1.6 rockers for future use if you buy it, so you can more accurately calculate lift. Lets see, buy the looks of the accelerator pump diaphragm in front that is a Holley carb. Not sure if it is a double pumper without looking at both sides of it. He is running an MSD box on it, what kind of distributor does it have? An HEI GM one or an MSD one?Not the worst built 350 by his numbers, but you would need to know more about the pistons, name brand, rods, crank, cam size, etc. Are the heads aluminum or iron?THe carb is not hard to work on at all. Holleys can be tuned with great ease. And they are dirt cheap to replace. Not the best carb for fuel efficiency, but for power, they are awesome. I grew up working on Holleys all day long. I can rebuild one blindfolded. Keep one thing in mind, you will be purchasing a car that will require lots of maintenance. You have no idea of the quality of the swap, or the wiring. Be prepared to have to redo somethings.I think 5500 to 6000 is not out of the question for this car. Maybe as high as 7000 since the body appears straight by the photos, but without closer inspection I will give him the benefit of the doubt. Link to comment Share on other sites More sharing options...
JayBrown Posted October 22, 2012 Share #14 Posted October 22, 2012 You gotta be spending pretty big if you want a car with that kind of performance mate. If you want to mount parts in your car then you could start canvassing and browse more auto parts that would just suits your deal. Sure the price would normally range up to a thousands of dollars but at least you'll get what you wanted. But make sure you spend your money wisely. Link to comment Share on other sites More sharing options...
sblake01 Posted October 22, 2012 Share #15 Posted October 22, 2012 Doubt that he'll hear you. Those were his only three posts on this site and he hasn't been here in almost six months. Link to comment Share on other sites More sharing options...
