Running a 2.8 on triple Dels. Facet 2 to 4 lb. fuel pump, filter before the pump, 5/16 hose all the way to the carbs, no pressure reg, no return, Carbs were pro rebuilt . It has run hard for the past few months. Out of the blue it dies out past 3500 rpm on the freeway only. On city streets it still runs ok. I have change the pump, lines, and filter with no joy. It will not even run at 3000 rpm on the freeway. Any ideas ?
https://www.classiczcars.com/forums/topic/41570-triple-guys-need-some-help/Share on other sites
