Posted December 10, 201113 yr comment_374150 yea new with this car could anyone tell me where the voltage regulator is at on a 78? thanks in advance Link to comment https://www.classiczcars.com/forums/topic/41605-voltage-regulator-location-on-a-78/ Share on other sites More sharing options...
December 10, 201113 yr comment_374153 It's inside the alternator case. Link to comment https://www.classiczcars.com/forums/topic/41605-voltage-regulator-location-on-a-78/#findComment-374153 Share on other sites More sharing options...
December 11, 201113 yr Author comment_374167 thanks i figured it was that, but was told there was an external as well Link to comment https://www.classiczcars.com/forums/topic/41605-voltage-regulator-location-on-a-78/#findComment-374167 Share on other sites More sharing options...
December 11, 201113 yr comment_374181 thanks i figured it was that, but was told there was an external as wellNot from 1978 and later. Link to comment https://www.classiczcars.com/forums/topic/41605-voltage-regulator-location-on-a-78/#findComment-374181 Share on other sites More sharing options...
December 11, 201113 yr comment_374184 thanks i figured it was that, but was told there was an external as wellTwo voltage regulators causes BAD things to happen.Download the factory service manual for your car. (Find the link in my signature.) Then you can look things up instead of relying upon hearsay. There is enough bad information floating around online that it is in your best interest to have the definitive repair manual on hand. Link to comment https://www.classiczcars.com/forums/topic/41605-voltage-regulator-location-on-a-78/#findComment-374184 Share on other sites More sharing options...
