Search on this site. Somewhere someone posted a colorized diagram of the 78 fusebox.
By the way, it is a good idea to put the year/model of your car in your signature. If you look at the submenu, you'll see Forum Actions. Click on that, and then click on Edit Profile. Then look on the left side of the screen for My Settings and find Edit Signature.
  sblake01 said:
The maxifuse setup I reacll discussing here in the past is actually used as a replacement for the underhood fusible links.
True. I think when most people consider replacing the fusebox, they are talking about the "Painless" kits.
For a stock replacement, your only choice is used, such as from ZCarSource.
