l28 in my 240k ?
nathan 240k
hi guys i no a l28 will bolt in 2 my 240k but can i put a l24 head to the l28 block . im thinking it would increase compression id would also use flat top pistons .ive done this with an l18 on a l20b block witch made a fair difference . is there any reason this cant b done ?
hay Nigel ive got the early 240k e30 head its off a 4 door 240k that i owned a few years back it had only done 50.000 ks from new so the head is in very good cond .so bigger valves and port it out should b ok .f54 l28 with flat top pistons and that e30 head should b a good thing
  • Who's Online   2 Members, 0 Anonymous, 108 Guests (See full list)
