Seeking Reliablility Advice
JpariZ
Should I purchase a Gear reduction Starter?
I just recently bought a new Patronix flamethrower coil and and electronic conversion kit for my hitatchi(sp) distributor in efforts to make starting my 72 240 a more reliable process. I found a gear reduction starter on ebay that has been refurbished and claims to be able to help with cold starts. If this is so then I would be more than happy to buy and replace it for my stock starter that constantly gives me problems. Will this disrupt anything else within in the engine or cause me to have to make any further modification? Can I get two cents from any one willing to offer some advice.
.....stock starter that constantly gives me problems. Will this disrupt anything else within in the engine or cause me to have to make any further modification?
It won't disrupt anything, it's a straight bolt-in swap. But it might not make a difference. What are the problems with the starter you have?
I've been noticing the cold weather starts are becoming more difficult, requiring a longer crank to get her pumping. When it starts it only runs on three cylinders at first unless the choke is fully engaged by stepping on the gas pedal while you pull the knob back. Then go half choke after a minute or so till it is up to temp.
  • 4 weeks later...
  • Who's Online   2 Members, 0 Anonymous, 453 Guests (See full list)
