Posted December 18, 201113 yr comment_374745 I can't turn off my radio/fan, where should I look first? this problem recently started, before it was running perfectly.Even with my Key in the Off postition, it stays on.Where should I start testing to figure this out? Link to comment https://www.classiczcars.com/forums/topic/41671-electrical-issue-radiofan-stays-on-when-car-is-off/ Share on other sites More sharing options...
December 18, 201113 yr comment_374746 Accessory Relay - The contacts might have welded closed. Look for it in the BE section of the FSM. If you don't have the FSM for your 77, look at the links in my signature. You MIGHT be able to disassemble the relay and unstick the contacts or tap the relay with a hammer to get them to unstick. Link to comment https://www.classiczcars.com/forums/topic/41671-electrical-issue-radiofan-stays-on-when-car-is-off/#findComment-374746 Share on other sites More sharing options...
December 18, 201113 yr Author comment_374749 thank you i'll check it out in the morning. also, could you tell me what the two plugs under the passenger seat are? i've been looking around, but i can't find any information regarding them. Link to comment https://www.classiczcars.com/forums/topic/41671-electrical-issue-radiofan-stays-on-when-car-is-off/#findComment-374749 Share on other sites More sharing options...
December 18, 201113 yr Author comment_374751 hmm, did some searching, and I cannot find an accessory relay?I did a quick search on here, and apparently the 1977 280z does not have an accessory relay.what else would I be looking for? Link to comment https://www.classiczcars.com/forums/topic/41671-electrical-issue-radiofan-stays-on-when-car-is-off/#findComment-374751 Share on other sites More sharing options...
December 18, 201113 yr comment_374757 hmm, did some searching, and I cannot find an accessory relay?I did a quick search on here, and apparently the 1977 280z does not have an accessory relay.what else would I be looking for?Okay, I looked it up myself and found it. It is called the Ignition Relay, and it is in the FSM. So you have not eliminated that as the source of your problem. Link to comment https://www.classiczcars.com/forums/topic/41671-electrical-issue-radiofan-stays-on-when-car-is-off/#findComment-374757 Share on other sites More sharing options...
December 18, 201113 yr Author comment_374828 Okay, I looked it up myself and found it. It is called the Ignition Relay, and it is in the FSM. So you have not eliminated that as the source of your problem.ok now i have a new problem.when i turn the key to acc, everything turns on as it should; however, when i switch to "on" everything turns off, and when i turn it back to acc nothing turns on unless i go to "off" then back to acc.do i need a new relay? Link to comment https://www.classiczcars.com/forums/topic/41671-electrical-issue-radiofan-stays-on-when-car-is-off/#findComment-374828 Share on other sites More sharing options...
December 19, 201113 yr comment_374838 Thanks. The extra details help. This is starting to sound like the contacts on the back of the ignition switch might be going bad. It fits both scenarios. Link to comment https://www.classiczcars.com/forums/topic/41671-electrical-issue-radiofan-stays-on-when-car-is-off/#findComment-374838 Share on other sites More sharing options...
December 19, 201113 yr Author comment_374842 Thanks. The extra details help. This is starting to sound like the contacts on the back of the ignition switch might be going bad. It fits both scenarios.i took apart my ignition relay, and it had a bad ground. I soldered a new wire on, and everything is working as it should now.now my electrical problems are these...i connected a 12v to my pump, my car starts and holds idle for about 5 seconds and then starts dying. throttle doesn't rev the engine, and neither does manually moving the AFM.my turn signals don't work, but everything else works as it should.my ignition relay is perfectly fine.my injector/pump relay is fine.turns signals don't work.pump only turns on with solenoid disconnected and key turned in the start position.i'm getting so lost as to what to check for... Link to comment https://www.classiczcars.com/forums/topic/41671-electrical-issue-radiofan-stays-on-when-car-is-off/#findComment-374842 Share on other sites More sharing options...
December 19, 201113 yr comment_374867 First, don't lump your problems together unless you KNOW they have a common source.The best way to track down these problems is to start at one end of the circuit and trace it all the way to the other end. The point at which you gain/lose signal (voltage) is your likely component failure. (By the way, I'm glad you found the bad ground.) The tricky part is when the problem is intermittent. With your EFI, that does not appear to be the case.Find a copy of the wiring diagram. Blue has one at his site. The best thing to do is download it and take it to Fed Ex/Kinkos to get it printed out large & in color. That will help you immensely with your diagnostics when matched with the FSM & FI bible. Link to comment https://www.classiczcars.com/forums/topic/41671-electrical-issue-radiofan-stays-on-when-car-is-off/#findComment-374867 Share on other sites More sharing options...
December 19, 201113 yr Author comment_374868 well my problem originally started when i parked at the store and when i came back 5 minutes later, my car refused to start. before this, my car ran beautifully, 18mpg, great power to the wheels, and all electrical components worked.all of this has started since then, that's why i believe its a common source. Link to comment https://www.classiczcars.com/forums/topic/41671-electrical-issue-radiofan-stays-on-when-car-is-off/#findComment-374868 Share on other sites More sharing options...
December 19, 201113 yr comment_374869 So then check your fusible links. That means pulling the links and checking resistance. Also examine the boxes that hold the links. Look for corrosion or heat degradation (melting). Link to comment https://www.classiczcars.com/forums/topic/41671-electrical-issue-radiofan-stays-on-when-car-is-off/#findComment-374869 Share on other sites More sharing options...
December 19, 201113 yr Author comment_374870 also, currently now, my car will turn over with a 12v hooked up to my fuel pump, but it dies after 10 seconds, and I cannot rev the engine at all. Link to comment https://www.classiczcars.com/forums/topic/41671-electrical-issue-radiofan-stays-on-when-car-is-off/#findComment-374870 Share on other sites More sharing options...
