i'm trying to diagnose my EFI, but I have no idea what an ignition lead wire is.
a photo would help me out a lot. there's a picture in the booklet, but it's hand drawn, and it's not where it says it is in the book.
Take a picture or copy the photo you're talking about and post it. Describe the booklet you're looking at. Describe the problem you're trying to diagnose.
OR. Type "ignition lead wire" in to Google and a picture will pop up.
it doesnt show up in google
the fuel injection says to check for power at the ignition lead wire and i cannot find it ive practically dtrippes my car completely down and i have no clue what it is
Okay, you're dropping details. Are you referring to the Fuel Injection Bible? What page? With more relevent information, you'll get better, faster answers.
I see that you're trying to do everything from a phone. Find a computer and spend a few minutes on it. On Google, the ignition lead wire shows up as the main wire from the center of the distributor cap. But that will only have power when spark is generated, so it's probably not the one you're looking for.
If you're checking for spark, you can do everything you need to do right at the coil, with a voltmeter and a jumper wire.
