December 26, 201113 yr Author comment_375453 Thank you guys for all the help. Will let you all know what I end up doing. May have to do some SS line work also after seeing Mike W's write up.Bryce Link to comment https://www.classiczcars.com/forums/topic/41714-what-electric-fuel-pump-upgrade/?&page=2#findComment-375453 Share on other sites More sharing options...
April 5, 201213 yr comment_386457 Can you elaborate more on the location of the wire in the dash. I am about to pull the console looking for it!! Link to comment https://www.classiczcars.com/forums/topic/41714-what-electric-fuel-pump-upgrade/?&page=2#findComment-386457 Share on other sites More sharing options...
April 6, 201213 yr comment_386475 The easiest way is just to pull a new power line - run it through the transmission tunnel - connect it a power supply tie to your starter switch - put it all on a relay with ground - tie a fuse into your line and your done. A 15-30 minute job at max. Link to comment https://www.classiczcars.com/forums/topic/41714-what-electric-fuel-pump-upgrade/?&page=2#findComment-386475 Share on other sites More sharing options...
April 6, 201213 yr comment_386541 I also got Carter GP-4070, but still haven't install yet.Is there any quiet electric fuel pump recommendation? Link to comment https://www.classiczcars.com/forums/topic/41714-what-electric-fuel-pump-upgrade/?&page=2#findComment-386541 Share on other sites More sharing options...
April 16, 201213 yr comment_387243 I also got Carter GP-4070, but still haven't install yet.Is there any quiet electric fuel pump recommendation?I think I have the same pump, and I have it all hooked up and will hopefully fire it up tonight. A lot of how loud these pumps are is in how you mount them. If your carter is the same as mine, then it came with rubber bushings. I put those in between the frame and the pump bracket, AND in between the pump and the pump bracket. The pump is double isolated. It still may be loud, but the install is clean and extremely rugged and durable. I will let you know how she performs, hopefully in less than 24 to 48 hours. Link to comment https://www.classiczcars.com/forums/topic/41714-what-electric-fuel-pump-upgrade/?&page=2#findComment-387243 Share on other sites More sharing options...
March 7, 20187 yr comment_543996 On ‎12‎/‎25‎/‎2011 at 1:33 PM, Pop's Z said: FWIW, to answer your question about the Carter fuel pump...that's the one I picked after reading Dave's site like you did. It works fine. I put a NAPA fuel filter between the tank and the pump. I did get a pressure regulator and mounted it after the fuel filter in the engine compartment. The Carter is a bit noisy, but once you get going the noise is drowned out by the exhaust/stereo. Cheers, Mike Have you ever measured the pressure of your Carter P4070 Electric pump before the carbs? How much pressure? Link to comment https://www.classiczcars.com/forums/topic/41714-what-electric-fuel-pump-upgrade/?&page=2#findComment-543996 Share on other sites More sharing options...
March 7, 20187 yr comment_543998 My cheapo AirTex fuel pump gives me 2.3PSI at the carbs & my bowls have never run dry. Link to comment https://www.classiczcars.com/forums/topic/41714-what-electric-fuel-pump-upgrade/?&page=2#findComment-543998 Share on other sites More sharing options...
March 7, 20187 yr comment_543999 I've run Carter and inexpensive Facet pumps on my Z for 40 years. Both have worked well until "end of life" necessitates replacement. Even the stock mechanical pump was adequate until I chose to go electric for no particular reason other than the newer Zs had electric pumps. Dennis  Edited March 7, 20187 yr by psdenno Link to comment https://www.classiczcars.com/forums/topic/41714-what-electric-fuel-pump-upgrade/?&page=2#findComment-543999 Share on other sites More sharing options...
March 8, 20187 yr comment_544020 Thanks. Im keeping the airtex 8012s pump even though it just pushes 3 psi. Link to comment https://www.classiczcars.com/forums/topic/41714-what-electric-fuel-pump-upgrade/?&page=2#findComment-544020 Share on other sites More sharing options...
August 24, 20186 yr comment_556067 I'm finally getting around to replacing the manual fuel pump with an electric pump on my '73 240Z with duel webbers. It seems most people who have swapped out for an electrical pump, mount the pump close to the gas tank. Other than running a little more wire and fuel tubing, is there any disadvantages of mounting the electric fuel pump in the engine compartment? Link to comment https://www.classiczcars.com/forums/topic/41714-what-electric-fuel-pump-upgrade/?&page=2#findComment-556067 Share on other sites More sharing options...
August 24, 20186 yr comment_556068 DugsZ -- Electric fuel pumps are better at "pushing" than "pulling" thats why you mount it near the tank. Mechanical pumps are the opposite, they do great with suction. Link to comment https://www.classiczcars.com/forums/topic/41714-what-electric-fuel-pump-upgrade/?&page=2#findComment-556068 Share on other sites More sharing options...
August 25, 20186 yr comment_556136 Thanks for the prompt and informative reply. Link to comment https://www.classiczcars.com/forums/topic/41714-what-electric-fuel-pump-upgrade/?&page=2#findComment-556136 Share on other sites More sharing options...
