Posted December 26, 201113 yr comment_375470 My water **** has recently started leaking. While I'm changing that out I will also be replacing the heater core, whatever new hoses are available and the part I will be needing. My '74 had A/C.(no longer) The hose connector between the engine compartment and the passenger side of the firewall is currently with the A/C vacuum water **** that comes just before the water valve that you adjust the temperature with. I no longer need that piece. What I'm looking for is the Non A/C hose connector. I have a pic of what I'm looking for. This can also be found in the '74 FSM on AC-55. <-- Click to enlarge this may also be the same in earlier and/or later models, not sure about that. Let me know if anyone has access to one of these that would be willing to part with it. Thanks Bobby Edited December 26, 201113 yr by Bobby_Lee Link to comment https://www.classiczcars.com/forums/topic/41742-non-ac-part-needed-for-swap/ Share on other sites More sharing options...
December 26, 201113 yr comment_375483 Looks like #14? ASSY-CONNECTOR WATER 27190-N3100 http://www.carpartsmanual.com/datsunS30/DatsunZIndex/Electrical/CarHeater/FromAug73/tabid/1667/Default.aspxGoogle that PN, if you think it's the right one... Link to comment https://www.classiczcars.com/forums/topic/41742-non-ac-part-needed-for-swap/#findComment-375483 Share on other sites More sharing options...
December 27, 201113 yr Author comment_375489 Thanks Willoughby Z. That is exactly the part and with that part number I was able to find it at JDM-car-parts.com $85 with free shipping. Thanks again! Bobby Edited December 27, 201113 yr by Bobby_Lee Link to comment https://www.classiczcars.com/forums/topic/41742-non-ac-part-needed-for-swap/#findComment-375489 Share on other sites More sharing options...
December 27, 201113 yr comment_375525 You're welcome. I also found the JDM site. Figured I would just give you the pole and tackle and let you bait and cast. Good luck. Link to comment https://www.classiczcars.com/forums/topic/41742-non-ac-part-needed-for-swap/#findComment-375525 Share on other sites More sharing options...
