Posted December 29, 201113 yr comment_375651 My seat driver side ( butt) foam is due for replacement , ADVICE:cool: Edited December 29, 201113 yr by 72 OJ Link to comment https://www.classiczcars.com/forums/topic/41767-seat-foam/ Share on other sites More sharing options...
December 29, 201113 yr comment_375655 www.classicdatsun.com Les has seat foam. Link to comment https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-375655 Share on other sites More sharing options...
December 29, 201113 yr Author comment_375658 Thanks....on my to do list Link to comment https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-375658 Share on other sites More sharing options...
December 29, 201113 yr comment_375659 Closer to you: Mike McGinnis at Banzai Motorworks. The foam is excellent. I just did my seats this week. Link to comment https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-375659 Share on other sites More sharing options...
December 29, 201113 yr Author comment_375661 Thanks,,, Link to comment https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-375661 Share on other sites More sharing options...
December 29, 201113 yr comment_375683 I can't remember the exact name of the shop, Classic Interiors or something close to that in west Baltimore, but there are plenty more shops around. They can “tune” the seat springs and reproduce the foam in a density of your choice to give you the level of firmness you want. It only takes a second to pull the seats out of a Z and drop them off. I would go that route. Link to comment https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-375683 Share on other sites More sharing options...
December 29, 201113 yr Author comment_375685 Good point...on my to do Link to comment https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-375685 Share on other sites More sharing options...
February 8, 201213 yr comment_380133 i need to replace foam and upholstery on both seats on 280z. also need to replace headlineri need to find a shop to order the foam. i think found the upholstery and headliner on zcarsourceis there a good video of how to do it on the web?can not find any shop in town to advise me. Link to comment https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-380133 Share on other sites More sharing options...
February 8, 201213 yr comment_380164 Recovering the seats isn't very difficult. Just take pictures as you're taking apart the old covers. I found that a dremel tool with a cut-off wheel was helpful for removing the hog rings. I also used slip-joint pliers on the new hog rings. Link to comment https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-380164 Share on other sites More sharing options...
February 9, 201213 yr comment_380275 Hey thanks for advice. Not sure what tools you are referring to, but will look them upnot sure if i am going with leather or vinyl. Probably leather.also not sure if the supports/springs are worn out also. i can feel horse hair like material under the seat right now. Link to comment https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-380275 Share on other sites More sharing options...
February 9, 201213 yr comment_380301 Can you somehow "enhance" the old "butt foam"? I'd love to re-do my seats but if i buy those covers, cannot afford the foam :'( Link to comment https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-380301 Share on other sites More sharing options...
February 9, 201213 yr comment_380341 SteveJ...my seats need redone. Thanks to your comment that they're not hard to do, I think I'm going to attempt the job myself. Best regards Link to comment https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-380341 Share on other sites More sharing options...
