I can't remember the exact name of the shop, Classic Interiors or something close to that in west Baltimore, but there are plenty more shops around. They can “tune” the seat springs and reproduce the foam in a density of your choice to give you the level of firmness you want. It only takes a second to pull the seats out of a Z and drop them off. I would go that route.
https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-375683
  • 1 month later...
i need to replace foam and upholstery on both seats on 280z. also need to replace headliner
i need to find a shop to order the foam. i think found the upholstery and headliner on zcarsource
is there a good video of how to do it on the web?
can not find any shop in town to advise me.
https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-380133
Hey thanks for advice. Not sure what tools you are referring to, but will look them up
not sure if i am going with leather or vinyl. Probably leather.
also not sure if the supports/springs are worn out also. i can feel horse hair like material under the seat right now.
https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-380275
Be warned that replacing the foam can cause you to sit higher in the car. Not an issue unless you are over 6 foot. I replaced mine a while back and now my head hits the roof when I go over bumps. This was never an issue with the old foam. I bought my foam from MSA along with their leather seat covers. You may have different results with other vendors.
https://www.classiczcars.com/forums/topic/41767-seat-foam/#findComment-380349
Recently Browsing 0
