Removed back hatch to redo defroster grid. Scraped defroster grid lines with razor blade and discovered that those grids are really on there. While I can't get them off that way I noticed they are now very smooth and shiny so I plan to put the new grid lines on top of the old ones. With my finger I can barely detect that the original lines are still there they are so thin even though they are easy to see. The old ones have high resistance everywhere I measure so they should not cause shorting with the new lines.
Edited by Mikes Z car
Almost ready to put engine in. Need to find a gasket for transmission. The PO took the rear extension off for some reason and gasket is torn. All the gears seem to work fine and engage...at least for now with no power going through it. Hope to get gasket this week, bolt transmission up, and put everything in. We'll see.
Brian
I dropped mine off at a local shop where the guy (a Z car mechanic from 80s California) asked to do my front suspension, while I try to repair the splash liners.
I replaced the thermostat...the old one was sticking...I also rewired the electric fans so they shut off with the ignition. I got the driver side dome light switch working. I also adjusted the SUs a little…All in all a productive day.
Got the hold-down bracket cut down and re-welded, painted and installed. Looks pretty spiffy now.
Next project is a new set of headers. Looking for 3-2, if you have a source, lemme know.
Frank,
When I saw you were looking for a 3 into 2 style header..I did a little searching..
found a couple sites...
these are what I had on my 3.1 stroker motor
http://www.nismoparts.com/catalog/?section=297
Here is another one I saw through a nissan dealership
http://www.nissanraceshop.com/product/332656/performance-lseries-header-system-6cyl-99996e1142
now keep in mind these are larger diameter headers..."race" applications...so to speak..more for a built motor that needs
to be "opened up" so to breathe better..
Do you have a stock motor in your Z? if you do, you might want to read through this forum topic :
http://www.classiczcars.com/forums/showthread.php?24866-240Z-Header-Recommendation
Edited by jackboxxx
Thanks, Jackboxxx. Like others, I'd like to get a set of Stahl headers, but understand they're no longer in business or have ceased producing for the L series. I found these on eBay, sold by a guy I've done business with before, http://www.ebay.com/itm/Datsun-Nissan-Z-280Z-240Z-N42-P90-E88-Ceramic-Coated-Square-Port-Header-NEW-/160709987854?hash=item256b0fce0e&item=160709987854&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr. I've written him inquiring of tube diameter and flange thickness. These headers have the square ports to fit my E31 head and from the photos appear to be pretty decent quality.
I'll further explore your other provided links via phone on Monday.
Many thanks!
Frank,
The last two headers mentioned in this thread are just MSA headers. You can get them way cheaper from MSA themselves.
Link
Nissan Motorsports still advertises their header, but as far as I know, you can't get those anymore.
(Actually done on Friday) Got the outside mirrors redone (new mirror glass) and the door/hatch locks to the locksmith for cleanup and repair of the dust flaps. Plus an appointment with the upholsterer to get the seats and door panels done.
Guest
This topic is now closed to further replies.
