About to Remove Ignition
AndysPlit
Not pry off, you'll have to notch them in order to use a straight screwdriver or use an awl to edge-hit the screw off. They're security screws and the heads have been snapped off, leaving a "blank" screw head.
The simplest procedure is to use a Dremel tool to cut a notch in the head of the "blank" screw, then use your straight screwdriver to remove the screws (2).
HTH
E
You can also use a bolt extractor bit. Just drill a little hole in the head, insert the bit, and turn. (It's not as easy as that, but if you have the bolt extractor set and not the dremel tool...)
Edited by FastWoman
