proportioning valve help
mjr45
Anybody got an exploded diagram of the proportioning valve or a good explanation of how it goes together, my old one cracked and the bone yard one was really gummed up, so like an idiot I took it apart, then got called away and forgot exactly how it goes back together (what a dumb arse).
The FSM and other on-line resources only show the exterior or the location of the valve, I need to know how the guts go back in the body, spring, washers etc. It has 2 22mm bolts (top and bottom) which are easy, they can only go one way, but the plunger springs and washers are another story.
