I want new rubber bushings on my car while the motors out. Do you all use Energy Suspension, Hyper-Flex? It's the most complete and most reasonably priced I've found, http://www.sparktecmotorsports.com/es-7-18102.html, experience, advice would be greatly appreciated. Thank you ahead. Cliff.
That is the 260/280 kit. If you have a 240z most of it will work but some items need to be trimmed.
I would recommend that you also buy the ball and socket tension-compression rod kit rather than use the poly parts in the kit.
Thank you Blue. Nothing but respect from your knowledge. I have '77 280 and will read up on the ball and socket tension-compression rod kit.
Thank you guys. I'm going to do what you suggest. Another $30 or so bucks plus the Hyper-Flex for night and day diffrence sounds great.
Edited by siteunseen
I've been reading a lot at atlanticz. I've found that "Yutaka Katayama" translates to "Blue" in English. Seriously though, Mr Blue has made anyone that owns a Zs life a little better. He should do a book and get rich then move somewhere warmer.
