April 10, 201312 yr Author comment_420111 look at this one I pulled off a 1976 fairlady Z.That's cool. Wasn't well-known to me that they changed it. That design is definitely better than the original. Not easy to clean out and still has the same stress/strain issues as the first design, but if it can handle it without failure, then no prob.They couldn't have offered that version for long... I've done bars for as late as 75, and in 77 they went to internally oiled? Maybe that was a 76 only thing? Link to comment https://www.classiczcars.com/forums/topic/41895-camshaft-oil-spray-bar-redesign-and-rebuild/?&page=5#findComment-420111 Share on other sites More sharing options...
April 10, 201312 yr comment_420115 A crude measurement using drill index shows .078 holes on the cam lobes of internally oiled cam.Interesting the size difference to do the same job. Link to comment https://www.classiczcars.com/forums/topic/41895-camshaft-oil-spray-bar-redesign-and-rebuild/?&page=5#findComment-420115 Share on other sites More sharing options...
April 10, 201312 yr comment_420123 Hey Captain, great idea and love the quality in the work. I have 2 71's that I would be interested using your upgrade on. Once you work out a price could you inform me of it. Would you need my oil lines sent to you?Thanks Newtonhubcap Link to comment https://www.classiczcars.com/forums/topic/41895-camshaft-oil-spray-bar-redesign-and-rebuild/?&page=5#findComment-420123 Share on other sites More sharing options...
April 11, 201312 yr Author comment_420181 A crude measurement using drill index shows .078 holes on the cam lobes of internally oiled cam.Yeah, interesting that the hole diameters are different. I have never messed with it, but I've heard there is a flow restrictor in the oil passage leading up from the block into the head. The prevalent theory being that you could completely open flow the oil in the head (like dumping all your oil out of a cracked spray bar) and you would still have enough pressure at the crank that you wouldn't waste your mains. You would ruin the upper end, but the crank should survive.If that's the case, then maybe they opened the holes in the cam so it wouldn't shoot so far? When it's not leaking all over the place, those spray bars really spray. Like... Multiple inches of spray.With the holes in the lobes, you only have to hit the follower. Anything sprayed on the underside of the valve cover really doesn't do you any good. Just thinking out loud...? Link to comment https://www.classiczcars.com/forums/topic/41895-camshaft-oil-spray-bar-redesign-and-rebuild/?&page=5#findComment-420181 Share on other sites More sharing options...
April 11, 201312 yr Author comment_420184 Hey Captain, great idea and love the quality in the work. I have 2 71's that I would be interested using your upgrade on. Once you work out a price could you inform me of it. Would you need my oil lines sent to you?All of the bars I've refurbished started with the original tubes. I've not made replacement tubes to date. Sometimes I wonder if it would be easier to remake the tubes from scratch as well, but so far, I haven't done that.I'll dig out my notes tomorrow in the shop... Link to comment https://www.classiczcars.com/forums/topic/41895-camshaft-oil-spray-bar-redesign-and-rebuild/?&page=5#findComment-420184 Share on other sites More sharing options...
July 31, 201311 yr comment_428869 hey captain, i have a 73 240Z with the same issues as everyone else here. I would love to know how much your are selling your upgrade for? PM me if you can, thank you!!!!! Link to comment https://www.classiczcars.com/forums/topic/41895-camshaft-oil-spray-bar-redesign-and-rebuild/?&page=5#findComment-428869 Share on other sites More sharing options...
August 7, 201410 yr comment_452880 Guys I am so sorry for reviving a dead thread but I am Highly interested in either or; a billet spray bar/redesigned spray bar. I've tried to contact Hassle/Cox, that number has changed. I've pm'd the captain, but no reply yet. Any leads would be helpful.TIA,JOEL Link to comment https://www.classiczcars.com/forums/topic/41895-camshaft-oil-spray-bar-redesign-and-rebuild/?&page=5#findComment-452880 Share on other sites More sharing options...
August 7, 201410 yr comment_452888 Look at Post #34 in this thread, it might be a new number. It looks like you'll have to call the number though, not use the email address.Spray bar MIA - Page 3 - Nissan L6 Forum - HybridZ Link to comment https://www.classiczcars.com/forums/topic/41895-camshaft-oil-spray-bar-redesign-and-rebuild/?&page=5#findComment-452888 Share on other sites More sharing options...
August 7, 201410 yr comment_452897 As seen on HybridZ:Larry Hassler and Chris Cox ( 626-485-1556 ) are selling billet aluminum spray bars. Unknown price, and I have not seen one in person. Just passing on info.Phredcorrect this number here is no longer any good to contact for a spray bar. DEAD END.Look at Post #34 in this thread, it might be a new number. It looks like you'll have to call the number though, not use the email address.Spray bar MIA - Page 3 - Nissan L6 Forum - HybridZSpray bar MIA - Page 2 - Nissan L6 Forum - HybridZ Thank You! I Will call in the morning. SWEET SUCCESS HERE! Edited August 7, 201410 yr by Nite_Grind Link to comment https://www.classiczcars.com/forums/topic/41895-camshaft-oil-spray-bar-redesign-and-rebuild/?&page=5#findComment-452897 Share on other sites More sharing options...
August 7, 201410 yr comment_452905 This is slightly off topic but even thou the major belief is that all the oil spray bars are identical through out the years, look at this one I pulled off a 1976 fairlady Z. It had an e88 head thou and I don't believe that was stock on the L20. [ATTACH=CONFIG]62455[/ATTACH][ATTACH=CONFIG]62456[/ATTACH]It seems to be a stamped block design rather than a cast, not sure on how well this works but there is no wiggle in any of the tubes.That's the one my late '76 build date but titled a '77 with an oiler cam plus spray bar N47 has. It has paper thin gaskets too. Edited August 7, 201410 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/41895-camshaft-oil-spray-bar-redesign-and-rebuild/?&page=5#findComment-452905 Share on other sites More sharing options...
August 7, 201410 yr Author comment_452910 Nite_Grind, Got your PM. Sorry I was out of town.Did you have any luck getting in touch with that guy on HybridZ at that new phone number? Hopefully he hooked you up, but if not, I sent you a PM back with some info. Link to comment https://www.classiczcars.com/forums/topic/41895-camshaft-oil-spray-bar-redesign-and-rebuild/?&page=5#findComment-452910 Share on other sites More sharing options...
August 7, 201410 yr comment_452930 Found another source for the cam oilers. A little bit spendy - Cam Oiler 70-77 Billet Aluminum: Engine Z - Misc. Engine Parts - 30202-ENEN - Z Specialties Online Store - If we don't have it in stock, we can get it! Link to comment https://www.classiczcars.com/forums/topic/41895-camshaft-oil-spray-bar-redesign-and-rebuild/?&page=5#findComment-452930 Share on other sites More sharing options...
