Posted January 11, 201213 yr comment_377202 I've searched, called parts stores, and even Nissan... No one can get it anymore :/ I'm wondering if anyone knows anyone selling one or where I may be able to find a new one? I went to a local junkyard and picked 2. Both off 280's and neither of them seem to work. Any help would be appreciated.Jake 559-270-7750Shaw.Jacob.js@Gmail.com Link to comment https://www.classiczcars.com/forums/topic/41910-wtbneed-help-findind-dropping-resistor-77-280/ Share on other sites More sharing options...
January 11, 201213 yr comment_377207 They don't really do much work besides convert a small amount of electricity to heat. I don't think that they go bad very often. Have you measured resistance and continuity? The test is described in the FSM Engine Fuel chapter. Link to comment https://www.classiczcars.com/forums/topic/41910-wtbneed-help-findind-dropping-resistor-77-280/#findComment-377207 Share on other sites More sharing options...
January 11, 201213 yr Author comment_377215 I'm pretty new to S30's. I bought a z, and its bit getting power to the injectors or f.pump... From all if the research I've done, it sounds lime that's my problem. I've replaced it with 2 others that I got off Z's in the junkyard. Link to comment https://www.classiczcars.com/forums/topic/41910-wtbneed-help-findind-dropping-resistor-77-280/#findComment-377215 Share on other sites More sharing options...
January 11, 201213 yr comment_377220 You'll save yourself a lot of time, money and aggravation, in both the short and long run, if you download the Factory Service Manual, and read the Engine Fuel chapter, and do some testing. It's free - http://www.xenons30.com/reference.htmlIf "bit" means "not" then it's unlimely the dropping resistors are bad because they have nothing to do with power to the fuel pump. Blown fusible links or bad connections are a more limely cause.Good luck. Link to comment https://www.classiczcars.com/forums/topic/41910-wtbneed-help-findind-dropping-resistor-77-280/#findComment-377220 Share on other sites More sharing options...
January 12, 201213 yr comment_377229 I suspect there is nothing wrong with them. The reason why they didn't work when you replaced them is probably because that isnt the problem. If you want to be sure, just check per instruction in the fsm, it will take 10 minutes and help you move on. They rarely(never) go bad. Link to comment https://www.classiczcars.com/forums/topic/41910-wtbneed-help-findind-dropping-resistor-77-280/#findComment-377229 Share on other sites More sharing options...
January 12, 201213 yr comment_377230 Zed Head......you're killing meLOLLOLLOL Link to comment https://www.classiczcars.com/forums/topic/41910-wtbneed-help-findind-dropping-resistor-77-280/#findComment-377230 Share on other sites More sharing options...
January 12, 201213 yr comment_377238 Zed Head......you're killing meLOLLOLLOLSeems like a fair trade. Gotta have a little fun now and then... Link to comment https://www.classiczcars.com/forums/topic/41910-wtbneed-help-findind-dropping-resistor-77-280/#findComment-377238 Share on other sites More sharing options...
January 12, 201213 yr comment_377247 Buy one of these:http://www.harborfreight.com/catalogsearch/result?keyword=volt+metermeasure the resistance of the ballast resistor with it disconnected from the car. It should have about 2 ohms of resistance, give or take. Link to comment https://www.classiczcars.com/forums/topic/41910-wtbneed-help-findind-dropping-resistor-77-280/#findComment-377247 Share on other sites More sharing options...
January 12, 201213 yr Author comment_377328 I got m,y volt meter back yesterday. Did some testing. Found a loose connection. I already downloaded the EFI guide as well as any other FSM I could find. Thanks for the replies. .... Now the next problem I have is this..... Loss of power while driving below 2500rpm (a backfire here and there and/or bad surge/sputter) Once I get above 2500, she runs fantastic. I'm doing some searching on that now. If you have any ideas on the cause of that, I'm all ears... Or eyes . Link to comment https://www.classiczcars.com/forums/topic/41910-wtbneed-help-findind-dropping-resistor-77-280/#findComment-377328 Share on other sites More sharing options...
January 13, 201213 yr comment_377370 Sounds like its running lean. There are some lengthy threads on those issues, it's common Link to comment https://www.classiczcars.com/forums/topic/41910-wtbneed-help-findind-dropping-resistor-77-280/#findComment-377370 Share on other sites More sharing options...
