Posted January 13, 201213 yr comment_377375 On my 73 the PO didn't connect the right side air/vent/heat cable, found it hanging in the wind. Where and how does the cable mount to the underside of dash? Link to comment https://www.classiczcars.com/forums/topic/41930-73-air-vent-cable-mounting/ Share on other sites More sharing options...
March 29, 201213 yr Author comment_385665 Can someone take a quick pic of the passenger side underdash area, right side of blower motor? I have an idea where the cable clamp goes but I'm not certain. Link to comment https://www.classiczcars.com/forums/topic/41930-73-air-vent-cable-mounting/#findComment-385665 Share on other sites More sharing options...
March 29, 201213 yr comment_385670 This might helphttp://www.classiczcars.com/forums/showthread.php?32556-Heater-cables-73&highlight=heater+cables Link to comment https://www.classiczcars.com/forums/topic/41930-73-air-vent-cable-mounting/#findComment-385670 Share on other sites More sharing options...
March 29, 201213 yr comment_385673 Link to comment https://www.classiczcars.com/forums/topic/41930-73-air-vent-cable-mounting/#findComment-385673 Share on other sites More sharing options...
March 30, 201213 yr Author comment_385677 I have the Haynes and also the FSM but neither is definitive in how the cable sheath is held in place. There are small clips that hold the sheaths for the other three cables but I can't figure out how the air/vent/heat cable is secured. Link to comment https://www.classiczcars.com/forums/topic/41930-73-air-vent-cable-mounting/#findComment-385677 Share on other sites More sharing options...
March 30, 201213 yr comment_385681 Link to comment https://www.classiczcars.com/forums/topic/41930-73-air-vent-cable-mounting/#findComment-385681 Share on other sites More sharing options...
March 30, 201213 yr comment_385683 Link to comment https://www.classiczcars.com/forums/topic/41930-73-air-vent-cable-mounting/#findComment-385683 Share on other sites More sharing options...
March 30, 201213 yr Author comment_385687 Thanks, Blue. But I need the mounting point of the cable that runs around the right side of the blower motor. Link to comment https://www.classiczcars.com/forums/topic/41930-73-air-vent-cable-mounting/#findComment-385687 Share on other sites More sharing options...
March 30, 201213 yr comment_385711 I believe it can be seen in the last 3 photos. It connects to the damper that directs fresh/recycled air. Use the fan that is also inside that assembly for orientation. You can follow the cable in this photo: Link to comment https://www.classiczcars.com/forums/topic/41930-73-air-vent-cable-mounting/#findComment-385711 Share on other sites More sharing options...
