  • 2 months later...
I have the Haynes and also the FSM but neither is definitive in how the cable sheath is held in place. There are small clips that hold the sheaths for the other three cables but I can't figure out how the air/vent/heat cable is secured.
I believe it can be seen in the last 3 photos. It connects to the damper that directs fresh/recycled air.
Use the fan that is also inside that assembly for orientation.
You can follow the cable in this photo:
