Posted January 16, 201213 yr comment_377730 My fule gauge was working and then just stopped. I pulled the sender and It tested of 13 to 79 ohms. checked the fuse and it is ok, so anybody have any thoughts on what to check next. oh yea all the rest of the gauges or ok.Joe Link to comment https://www.classiczcars.com/forums/topic/41965-77-280z-fuel-gauge/ Share on other sites More sharing options...
January 16, 201213 yr comment_377733 It sounds like you're doing good diagnostics so far. I suggest testing the fuel gauge out of the car. Hook up the Green, Yellow, and Black wires from the gauge to 2 lantern batteries and a 100 Ohm potentiometer as shown in the drawing. Vary the resistance on the potentiometer, and you should see the needle move. Link to comment https://www.classiczcars.com/forums/topic/41965-77-280z-fuel-gauge/#findComment-377733 Share on other sites More sharing options...
January 16, 201213 yr Author comment_377737 Thanks it was also what i was thinking would be the next step. I have a dash cover which makes getting gauges out difficult, so I may try to do from the plug. Link to comment https://www.classiczcars.com/forums/topic/41965-77-280z-fuel-gauge/#findComment-377737 Share on other sites More sharing options...
January 16, 201213 yr comment_377740 As long as you can still remove the panel with the vents & map light, you should be able to remove the gauges that way...unless you have AC. Link to comment https://www.classiczcars.com/forums/topic/41965-77-280z-fuel-gauge/#findComment-377740 Share on other sites More sharing options...
January 16, 201213 yr Author comment_377741 I have AC, but it is a labor of love. Link to comment https://www.classiczcars.com/forums/topic/41965-77-280z-fuel-gauge/#findComment-377741 Share on other sites More sharing options...
January 16, 201213 yr comment_377778 MY fuel gauge (1976) stopped working about two weeks ago. I pulled it out to replace it with one from another car, checked the various circuits to see where the problem was and couldn't find any. Put the old one back in and it worked correctly. I don't know if the connector just worked itself loose (we were in the first really cold weather of the year) or the needle just got stuck and it jarred free when I took the gauge out. Link to comment https://www.classiczcars.com/forums/topic/41965-77-280z-fuel-gauge/#findComment-377778 Share on other sites More sharing options...
January 16, 201213 yr Author comment_377789 Thanks for your help I got it working. All i did was clean all the connectors in including the fuse box connection and it started working. Link to comment https://www.classiczcars.com/forums/topic/41965-77-280z-fuel-gauge/#findComment-377789 Share on other sites More sharing options...
